Xbox 360 accessories and their compatibility with Xbox One
I bought Xbox 360 game console last year and I gave it out to a friend as a birthday present but I forgot to add all the accessories even though she bought a brand new set of Xbox 360 accessories. I have bought Xbox One just last month and I wanted to know if it is possible for me to use my Xbox 360 accessories to work on Xbox One?
Thank you.
Answered By 0 points N/A #188474
No, it is possible for you to work your “Xbox 360” gaming console accessories with “Xbox One” gaming console. There are some points which show that “Xbox One” is not compatible as per with the “Xbox 360”. These are as follows:
· You cannot play your “Xbox 360” games with “Xbox One” gaming console.
· You cannot play with your “Xbox 360” controllers or any other accessories with the “Xbox One” gaming console.
· You cannot plug your removable hard drive of “Xbox 360” gaming console into the “Xbox One” gaming console because it is not compatible with the “Xbox One” gaming console.
· You cannot stand your “Xbox One” gaming console vertically like the “Xbox 360” gaming console.
· You cannot use the power supply from “Xbox 360” gaming console into the “Xbox One” gaming console.
Hope this answer will help you a lot.
