Kemp Lax
Posted on - 05/29/2017
I’m a student and I love playing Xbox games. Since a few days. My Xbox is not working properly. I’ve heard about the Xbox error code of Xbox 360. It’s showing 3 flashing lights and it’s creeping the hell out me. What should I do?
XBOX 360 Error Code – The Famous Red Ring Of Death
– It’s the Xbox error code. You may sometimes see this flashing light getting in the way of your gaming victory. While there are more than 65 errors of different varieties , each with a different meaning, the 3 light sequence is the worst and one of the most basic errors.
You can take your xbox to a techie, but before that you can try troubleshooting your xbox in a much faster way. Follow these steps:
1. Hold down the “sync “button on your console, if you see the 3 light button.
2. Simultaneously, press the eject button. Each time you press these buttons together, you get a series of flashes. Note the number of times of flash:
Four times – 0
Three times – 3
Two times – 2
One time – 1
Place entirely of the numbers together in the order they looked. This will give you a four digit code. This code gives you an issue with your power supply. For a list of the codes and their meanings, look at this website.
