Xbox Application Opening Time 0x80080300 Error Message Occur
What is the 0x80080300 error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x80080300 error is an Xbox error, and it occurs when the user tries to open the Xbox in the Windows application. The user will be unable to sign-in to the Xbox, and it will be the issue.
The steps to fix the 0x80080300 error message are:
Method 1:
Perform a clean boot.
• Sign in to the computer as an administrator.
• Type “msconfig” and open System Configuration from the result.
• Select Hide all Microsoft services and then select “Disable all” under the Services tab of System Configuration.
• Select Open Task Manager on the Start-up tab.
• Select an item and then select disable in the next options.
• Close the Task Manager and select OK on the System Configuration.
Method 2:
Uninstall and reinstall Xbox app manually.
• Click on Start, and type Windows PowerShell on the search box.
• Open the service and select run as administrator.
• Type the command: Get-Appxpackage *xboxapp* | Remove-AppxPackage and press Enter.
• Launch the Windows Store and download the Xbox App.
Method 3:
Check for Windows updates.
Method 4: Reset the application.
• Click on Start, then go to Settings and select System.
• Choose Apps & features, then find the Xbox app and click on Advanced option.
• Click on the Reset option.
• Restart the device and sign-in again.
Method 5:
Check Internet Connection.
