Xbox Backup Creator has encountered an error
I only use Backup Creator to rip the disc. When I try to write at your own peril, after initializing it hangs the disc on verbs. I am using pio111d 1.23. What shall I do to fix it? Any ideas would be greatly appreciated. Thanks in advance.
Xbox Backup Creator
Video Failed. Data is missing.
PFI Failed. Data is missing.
DMI Failed. Data is missing.
SS is present!
Stealth Check Failed!
Do you want to continue?
Yes No
