It needed 10-20 minutes to make everything ready, I attained max money, max affinities, level, and all unicorn cars but after that I got this error message when I was trying to save:
Forza 4 Profile
Error
An error has occurred while writing back to the loaded Rackage!
If you see a developer, the following message will help him resolve the issue:
The given key was not present in the dictionary.
OK
I am in doubt what the error message could really be.
I’m not sure if the error has something to do with the application since the error is pointing on a certain part of your table. See if you can save it as a backup then close the application and then restart your system. If there is no other way of saving your work then try copying all the data on another application like a text editor or something then save it. You can use this to copy and paste the data after maybe fixing the problem with your program.
If there is no way of saving it, then just follow the method above then close the application. After this, uninstall the program then install it back to have a fresh copy installed on your system. Restart your work again by simply copying the data from the previously saved file on to your new project.
If you are playing “Forza Horizon 4”, verify that you are playing the game with an administrator account. If this doesn’t work, check the system requirements again and make sure your computer meets those requirements. The game “Forza Horizon 4” supports Windows 10 only.
Forza Horizon 4
It requires 2.67 GHz Intel Core i3 or faster processor, 8 GB RAM, and video card with 2 GB video RAM and supports Pixel Shader 5.0 and Vertex Shader 5.0. If this doesn’t work, uninstall and reinstall the game. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select Forza Horizon 4 among the applications and click “Uninstall”.
Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo then install the game back.
For a little history, “Forza Horizon 4” is an open world racing game released on October 2, 2018 for Microsoft Windows and Xbox One developed by Playground Games and published by Microsoft Studios. This version is the fourth “Forza Horizon” title and the eleventh installment in the Forza series.
1....
