XDRiInfo returned with non-zero exit code.
I tried to run 3D acceleration application, but produce following error message.
I have 512 MB NVIDIA PCI express card, 2 GB DDR RAM with Duel core processor.
I also have the latest version of DirectX.
I am pretty sure that my hardware drivers are up-to-date.
Please anybody share with me the reason of this malfunction.
Wishes,
Daisy
Answered By 590495 points N/A #90397
I'm not sure what 3D acceleration application you are really running. Check again the application’s documentation for its minimum system requirements to know if your operating system is compatible with the program.
But if you are running PCBSD 7, here are its specifications:
Minimum system requirements
  • Pentium 2 or higher processor
  • 256 MB RAM
  • 6 GB available hard drive space
  • Network card
  • Soundcard
Recommended system requirements
  • Pentium 4 or higher processor
  • 512 MB RAM
  • 12 GB available hard drive space
  • Network card
  • Soundcard
  • 3D accelerated video card (NVIDIA or Intel)
Your hardware specifications are quite above the required application requirements. Since you did not mention the name of the 3D acceleration application you are running, try reading your program’s specifications so you’ll understand why it failed to run.
