XEN Server Problem As Restarted
On my computer I have the XEN server with the 5.6 service pack 2 version. Could you tell me why is it that every time I restart it, the LAN always shows to be disconnected?
Hi Alison,
You can run some test to check if your LAN card is still running perfectly, a simple ping or IP test would do. If this has been on going you may want to reset your router or download an updated firmware on it to fix any possible bugs.
You can also manually set your duplex speed by going to go to Network and sharing center > change adapter settings > right click on Local Area connection > Properties > click configure > Advanced tab > Look for Link Speed and Duplex > change the value from auto to 100 full duplex.
