Hi all,
I kept on bumping into this Xenocode 2008 error. I think it has to do when I run CCleaner. Any thoughts on this?
Thank you everyone.
Xenocode Postbuild 2008
The application encountered an error: (0xD0000002)
Please contact the publisher of this application for more information.
Xenocode Postbuild 2008 The application encountered an error
Hi there Jeff F French,
The first thing to do is to turn off the CCleaner, disable the autorun option, restart your computer and see if that changes anything.
If you're still getting the error, you could try updating your DirectX drivers.
Also, there is a known issue with the compatibility of older versions with the newer operating systems, so if none of the previous tips works, please update your software.Â
Best regards,
Drake Vivian
The error is because some of the system files are crashed.
There are multiple solutions to it.
Solution 1:
1) Right Click 'My Computer', go to 'Advanced' tab
2) Choose 'Disable error reporting option'
3) Click 'OK'
4) Restart the system
Solution 2:
1) Click 'Start', go to 'Control Panel'
2) Select 'Administrative Tools'
3) Find the 'Error Reporting Service'
4) Go into 'Properties', disable it
5) After disabling it, restart the system
