The XML document is not well-formed
Tech guys,
I am getting this error message when I open and close the File Zilla client. Recently updated my version but I had this problem in the previous version too. Is this a bug? And also I tried the common method of uninstall and reinstalling the program but nothing worked. Anyone is facing the same problem? Please share your thoughts. Thanks in advance.
The file ‘C:UsersSteveAppDataRoamingFileZillafilezilla.xml’ could not be loaded.
The XML document is not well-formed: Error reading end tag.
For this session the default settings will be used. Any changes to the settings will not be saved.
