XML failed to validate export data from table to in MS-Access
10 points
Posted on - 10/06/2012
Hi Experts,
Have a look at the error messages below. Microsoft Access has encountered this problem while importing table into the txt.
I am using Windows 7 64-bit. I tried several ways to get a remedy of this issue but failed.
I do not know what I should do now. If you have any idea for the issue, please help.
Thanks in advance.
The specification XML failed to validate against the schema. There is an error in the following line of the XML document: Â l.
                         OK
An error occurred trying to export data from table XXXXX. The data was not exported.
                          OK
