lance sok
10 points
Posted on - 07/18/2013
Hello Techyv Guys,
I have been searcing for a tool that will convert xml coding to corresponding sql coding. Is it possible to have a tool or to get xml to sql converter open source coding. Please help me by providing the same asap.
Thanks you in Advance,
Lance Sok
XML to SQL Converter open source coding
Hello Lance,
You can download a free trial of a program Called Total Excel Convertor, which converts XML to SQL. This program will allow you to make this conversion quickly and easily, as it utilizes batch conversion, meaning that you will be able to work with hundreds of XML files at a time. Total Excel Convertor–once installed–works by the user selecting the desired XML files, setting SQL as the format, and pressing "Start."
