XnView Bug Error, Log Out on Macbook Pro
Hello, I had trouble when I tried to start XnView (XnViewMP beta v0.39) on my Macbook Pro. I was able to open it but it crashes after.
The error message says Bug error, log out. I was looking for a software that would be able to invert a black and white pdf document and I can’t find any software to do it instantly.
Can you help me to fix this? I don’t have any idea what to do next as I am new to this software. Thank you for your time.
Answered By 590495 points N/A #159365
If you were able to successfully install XnViewMP 0.39 on your computer and only got a problem opening it, you should try checking your system for possible errors. Since it already doesn’t work anyway, uninstall it from your machine then check your computer for any possible errors.
Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities, PC Tools Performance Toolkit, or Norton SystemWorks.
I’m not sure if any of these applications have Mac versions but you can search the web for Mac version. After the disk check, install the program again and then open it afterwards to see if it works.
If it still doesn’t work, it’s possible that you have downloaded and installed an incorrect version for your Mac. To find the right version for your Mac OS X, visit https://newsgroup.xnview.com/viewtopic.php?t=26033.
I’m not sure what version of Mac OS you are using but this version only supports Mac OS X 10.5. I’m not sure if this will work on higher versions of Mac but if you are using an older version, you should upgrade to this version to make it work.
