Randy Baier
30 points
Posted on - 11/15/2012
Hello guys
I am using Sony Ericsson – XPERIA – X1.
I have a problem with – XPERIA  codecs.
I installed some video players and then uninstalled them as they didn’t work successfully.
So I have come back to my media player. But now my media player is also not working.Â
It just says cannot play the file.
Can anybody help?
Xperia codec’s problems: need help
Hello Mr. Randy Baier,
Please make sure that you are trying to play videos which are supported for your phone.
If you are sure that you are playing media file which is supported then please contact to Sony Ericsson.
I will recommend you to try these link to download your media player software. I am sure it will work for you.
Sony Ericsson Xperia x1 apps
Windows Media Player Sony Ericsson Xperia
Thanks very much.
Hi Randy Baier,
I have reviewed your issue; you are looking for Sony Ericsson – XPERIA – X1 codec pack.
I am providing a link, where you can find the Sony Ericsson – XPERIA – X1 codec pack.
You can download Sony Ericsson – XPERIA – X1 codec pack from the link:
And no need to install new players and just update your codec pack
I wish this solution may be helpful.
Thanks!
Best,              Â
Fenster Maxine
