I need help on playing Yahoo LAUNCHcast Radio on my Windows 7 PC. I’ve been using this for few almost a month without having any issues. I even reformatted my computer system due to other issues but the error on my LAUNCHcast is still persisting. I cannot make it work even if I already downloaded all the updates needed. What can I do to make my LAUNCHcast work again as it was before?
Yahoo LAUNCHcast Radio Not Working
Don't worry!
I have a better solution for fix this issue. If it show you unable to plug-in,Sing out form the application,Go to the top menu then click to"messenger".It will show you some icon,you need to click "connecting preference".now you need to click "connection directly to the internet".Then click "apply" and then "ok".
Now you can sing in,and lunch the plug-in.
If its work,Well! But If you seen it's not working. please follow below……….
1.Uninstall your application,Restart your computer.
2.After that,Download the latest yahoo messenger form yahoo web site.
3.Install the latest software and start began.
You can stop your any other plug-in program,For the determination.
Thanks!
