Yahoo messenger 11 for cellphone is not working.
Hello experts,
Yahoo messenger 11 for cellphone is not working. My yahoo messenger in my android Samsung galaxy s mobile phone is not working properly and cannot load all the contacts that I need to chat or talk with. I need to fix this issue as soon as possible for I am only using wireless internet connection while chatting with friends in yahoo messenger. What can I do regarding this issue? Thank you.
Best Answer by Patrickk Wilkins
Answered By 0 points N/A #173597
Hello Rebecca,
For the Yahoo Messenger to work, you will need to make sure that you have a stable connection to the internet. Also, make sure that the messenger is one that meant to run on your Android Samsung galaxy mobile, for you may have installed the desktop version.
Nicke
Answered By 0 points N/A #173598
Hello Dear,
Yahoo messenger you downloaded might be the proper one. Try installing the yahoo messenger for mobile. Moreover there can be the issue with the yahoo messenger you installed. Try removing the current version and install the latest one on your Samsung device. Try rebooting your device for smooth running as many problems are resolved by this activity.
Patrickk wilkins
