Yahoo messenger chat content always blank
What seems to be the problem of my Yahoo Messenger?
Before it was running fine but since yesterday the messages that I type don't appear but I can read all the messages from the person I am talking with.
Hi Luke Montego!
I would just like to ask if what version your Yahoo Messenger is?
You may be suffering from a Yahoo Messenger Bug.
To be able to fix this, you should do the following:
You can choose whatever you like to, but I suggest you SHOULD try everything.
Why there are many solutions to do?
Answer: To ensure you can resolve your problem. Remember, there is NO harm in trying.
Possible solution 1: Download Java (if you don't have yet, if you have, PLEASE reinstall it).
Possible solution 2: Enable all scripting option in Internet Security Settings.
You maybe have disabled scripting without knowing.
To be able to enable scripting, you should:
1. Go to Tools menu on your IE (Internet Explorer) toolbar.
2. Select Internet Options.
3. Select Security tab.
4. Select the Internet icon.
5. Select Custom Level button.
6. Look for Scripting.
It should be able to enable the following:
Activate scripting
Allow paste functions through script
Scripting of Java applets are all enabled
Lastly, select OK (can be found at the bottom of the window).
Possible solution 3: Enable following scripts:
1. Kindly click START (located at the task bar)
2. RUN and type following commands
a. regsvr32 wshom.ocx
b. regsvr32 jscript.dll
c. regsvr32 urlmon.dll
d. regsvr32 c:WindowsSystem32vbscript.dll
Else,
Watch the below video (instructions are stated in the video itself).
Nothing follows
If you are encountering problems, don't hesitate to give me a beep.
Notifications
