Yahoo Messenger Failed to Execute Last Action Error 100
Whenever I try to use Yahoo Messenger on my mobile phone, an error keeps on re-appearing. I have tried to reinstall the messenger for several times yet, when I opened it, the same error will occur. I'm not sure what to do next but I am keeping my fingers crossed that someone can help me on fixing this. Thank you.
Failed to execute last action (100)
OK
Answered By 590495 points N/A #123233
Check first if you are using the latest version of Yahoo! Messenger because sometimes the problem has something to do with the application’s version that conflicts with the Smartphone’s operating system which, on the other hand, is regularly updated. This is also similar as to when using a program in Microsoft Windows that suddenly went incompatible because of the recent update to the operating system.
You can try fixing your problem by downloading and installing the latest version of Yahoo! Messenger and you can download it depending on your handset or operating system. For iPhone and other iOS devices users, you can download Yahoo! Messenger 2.2.8. It requires iOS 4.0 and higher and supports iPhone, iPad, and iPod touch.
For users who have an Android Smartphone, you can download Yahoo! Messenger 1.8.4. It requires Android 2.0.1 and higher.
