My husband and I are working here abroad. We only have one computer.
My husband wants to work with me online at the same time.
I would like to know if it is possible to open two Messengers so we can log two different accounts.
COLBERT
Yahoo messenger username multiple login
Hey there!
Yes, it is possible to open multiple messengers from your PC at the same time. If you are using Yahoo that would be great because you just got to follow some simple steps and you would be able to use the multiple Yahoo Messengers from your PC easily.
For using Yahoo multiple messengers here are the steps:
1) Go to "start menu" and in "search" type in "regedit"
2)Now find out "HKEY_CURENT_USER". Open its list and find "software" and under software list find "yahoo" then find "pager", now right click on Test > New >and choose DEWORD Value. Then set new file name to "plural”, now click on it and change value number from 0 to 1 and press OK.
3) Now go to your Yahoo Messenger and open up messenger more than one time. It will open one messenger over other. Simply drag the upper messenger to view the other.
There you are you can now use two or many Yahoo messengers.
Enjoy 🙂
Colbert
