jackpol
230 points
Posted on - 05/27/2011
Hallo
I am jackpol,
I have a SYMPHONY mobile phone. I use internet from my mobile phone. Their have Yahoo Messenger but i don't login my yahoo messenger. Mobile show me a message " login failed your messenger". So i can't use my Yahoo Messenger but i want to login Messenger & chat with my friend. I don't understand this problem.
What can i do now? It's very painful for me i have a internet connection but i can't chat with my friend from my messenger. So my questions is " I want to login my yahoo messenger & chat with my friend".
Please give me a solution very quickly.
regards
jackpol
MayAnn
Can’t login on Yahoo using Symphony Mobile Phone
Hi there, My name is May
Now, there are a lot of possible things that could be generating your error, unless you give the specific kind of error message you are getting or any other thing you notice as you try logging in to your yahoo messenger in your SYMPHONY mobile phone. Here are some generic causes that may be helping you get this error of unable to log in to yahoo messenger:
Your connection may be weak, make sure your connection is strong and stable as this sometimes causes connection errors while logging in to yahoo messenger.
Incorrect internet settings. Your phone may have an incorrect setting or your yahoo messenger in your SYMPHONY phone may be causing errors due to wrong connection settings.
You may have a proxy setting, try to determine if your connection is using a proxy, you might need to set it up yourself.
There may be a lot more, but with the limited info you have given, all I can deduce to your problem is connection error. Hope this helps in discovering your problem and hopefully fixing it.
