Yellow Lines on Sophos Icon
Hello everyone
I installed a Sophos Anti Virus long back, after a few days it started showing yellow lines blinking on Sophos Icon. What does these yellow lines mean?
Thanks
Hello everyone
Thanks
If you are still using the old version of Sophos Anti-Virus you need to update to the new version because the old version will no longer be able to receive any product updates by December 31 2011 and it’s already past due. The new version of Sophos Anti-Virus can be downloaded at HERE.
This version of Sophos Anti-Virus supports Windows XP, Windows Vista, and Windows 7. But Sophos Anti-Virus is only for the students and staffs of the University of Bath. If you are not a member of that school you still won’t be able to access the download link provided above because it will require you to sign in.
If you are already using the new version of Sophos Anti-Virus, try uninstalling it then check your computer for any possible errors. Use a disk utility application to check the system. After that install the antivirus again and start updating it.
