Yogbox – Installer fails to launch the format
Hello all
I have OS windows 7 64 bit on my system and I have been using yogbox for quite some time . I installed it when it was as an installer and not in the launching format. Recently I have tried to update it but when I try to make a selection from the yogbox drop down menu, I get an error. The screenshot of the error is as follows:
Update Failed!
OK
To fix the issue, I ran it as an administrator but the same error popped up again. I also deleted both the spout and the minecraft folder and then tried to launch it but the same error persisted. I deleted the minecraft folder and then launched minecraft to update, then I provided the launcher but still the same error was seen on my screen.
 I searched a lot for the solution to this query and also scrolled down the FAQs but found no help. I also opened the yogbox help section, to my surprise such an error was not listed.
I also tried to install the newer version but it also ended up in the same error.
Can anyone please suggest what am I doing wrong and how to get rid of the error?
Looking forward to your response
Regards
