You can submit an error report to help us improve the quality
Friends,
Recently I have faced Windows error message while trying to play Dragon Nest game.
The following error encounters most of the time I try to load the game. I have absolutely no I idea about the problem.
Please share your expertise knowledge on this issue.
You have encountered an error in Dragon Nest, and the game must be closed.
We apologize for the inconvenience.
You can submit an error report to help us improve the quality of Dragon Nest.
The data you send will be kept confidential and will not include any of your personal information.
Wishes,
Joe
Best Answer by Harpe byers
Answered By 0 points N/A #94977
Hi Joe Simpson,
Whether you are playing patches games like the DRAGON NEST try to disable the anti-virus and Firewall and re-install the game.
Then if nothing happens completely uninstalling the whole game by seeking to the guide game and delete the Game folder and all the applications that support the game.
Or you can go to the registry look for the files and delete those related to it and try re-installing it again.
Hope this might help you.
Thanks,
Altheakaye14
Answered By 10 points N/A #94978
Dear Joe,
When you are playing games like Dragon Nest there are lots of chances that it comes with corrupted files and if your Firewall is on then it will not allow opening such corrupted files.
I would not suggest stopping firewall for a while because it can seriously damage your PC and you may lose important data or files.
Instead of that you shall download Dragon Nest game from a trusted web source .
Hope you will enjoy your game now!
