You have been kicked from the game. The reason is…
Last time when I tried to play Battlefield game an error message containing "You have been kicked from the game.
The reason is: PunkBuster kicked player
To resolve the problem I reinstalled the game manually but the problem is still present.
What is the solution? Should I have to reinstall the whole system?
Error:
You have been kicked from the game. The reason is: PunkBuster kicked player ‘xquizt’ (for 0 minutes)…. This pg Server Requires (AT1382 C2 220) – Error loading pbcl
Thanks
Lira
Best Answer by rabin
Answered By 0 points N/A #88947
Hello Agnes Lira,
 Try to talk with the admin of that server or go to their support to ask for your IP check. Either you got an IP banned in that specific game that unable you to join the game. Or the one who created the map keep kicking you like you were doing Trashtalk and he hate you. So he got the power as a leader of the game who create the individual maps or they are the one who hosted the game.
Otherwise ask the support of the game go to their chat room and ask if your IP is banned or what. That may solve it.
Thanks
Answered By 5 points N/A #88949
My solution to your problem, maybe the Battlefield requiring you to update your version just simply look the possibility version to your Battlefield from the Net, or if it’s not maybe there is a virus that effect to your Battlefield folder. After that just simply install or download the error repair tools to your machine to check or scan if there is a founded error to your battlefield games simply repair the error if it’s possible to your machine, and then attempt to download or install your machine the registry cleaner to clean out any problem to your system
Ben
Answered By 590495 points N/A #326657
The full error reads, “You’ve been kicked from this server by PunkBuster”. If you play “Battlefield” and this is the first time that you see this and you know it is may be an error, try to uninstall and reinstall PunkBuster. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select PunkBuster among the applications and click “Uninstall”.
Follow the normal uninstall process. When you are prompted to restart the computer, click to restart later. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo then restart the computer.
After booting, install PunkBuster back then add your Battlefield game to PunkBuster located on the top of the PunkBuster screen. If the problem continues, download the latest PunkBuster. Select the version for your operating system. PunkBuster is available for Microsoft Windows, OS X, and Linux. Once downloaded, unpack the ZIP file. You can use WinZip, WinRAR, or 7-Zip to unpack the files.
Run the PunkBuster setup file then add your game. Once Battlefield is added, update PunkBuster again located on the top of the screen.
