You have been logged into temporary profile
My laptop Asus x42j series, Core i7, VGA ATI Radeon 5470 1 GB, 4 G RAM, Windows 7 Ultimate Build 7601 SP1
Dear Silverman,
This is very common problem for windows computer. Here you did not mention that you computer is working under a domain or this is your personal computer. Anyway, no problem if it is under domain or single. Please do below steps.
1. Please shutdown your computer, if it is already open with temporary users.
2. Press power button and when display come then press F8 button then choose safe mode.
3. Login with Administrator account in the Safe mode window.
4. Then Open My computer, and then open C drive then open users.
5. Now Delete your user profile and restart computer.
Now Login with your previous user and do your work as previous.
I need to delete user profile for this problem? nice and I wanted to thank you for this informative analysis of the subject.
If everything seems to be disabled or not working and an error keeps appearing whenever you try to start a program, check your computer for virus infection. Update your antivirus or internet security then perform a full system scan. You can also use third-party software virus removal tool to scan your computer like Sophos Virus Removal Tool. Download the program and install it.
Once installed, start Sophos then wait for the virus signature database to get updated. When updating is complete, click to start scanning your computer. When a virus is found at the end of the scan, remove it then repeat the scan over and over until it no longer detects a virus. The program scans everything on your computer including USB devices connected via USB port.
You can use the tool even when you have an antivirus program and you don’t need to disable it to use the tool. It works alongside any antivirus program you may have. This program is just a virus removal tool and cannot be used as replacement for your antivirus program because it doesn’t have real-time protection. The program is functional only for several months.
When it reaches the end of its usability period, it will automatically stop working. If you want to use it again, you have to download a new copy.
