Two years before I had this mobile Samsung S7, which was in good condition. After some time, I started having some problems with the application I had downloaded from the play store. It uses to work for some time, and after some time whenever I clicked it to start the app, it starts and again comes back to the home screen along with the message
“Your last session closed unexpectedly.” Any solutions to it?
Your Last Session Closed Unexpectedly
This mainly occurs when you update your device software but forget to download App updates. Also, when your Wi-Fi is slow or cellular data is unstable, apps tend to malfunction. There is an easy to step to solve this problem.
• Go to settings
• Click on Apps
• Search for the app which closes unexpectedly
• Click on that app and clear the cache and if necessary, clear the data. Tap the force stop option
• Go back and start the app again
Hope this problem is solved
