DanielSmith
50 points
Posted on - 08/10/2011
Suspecting an infection on my Windows 7 Ultimate machine I installed a trail version of eTrust Anti Virus.
Performed a scan on the complete machine, but to my surprise it did not find anything at all.
I ran the HijackThis on my PC and it comes up with access denied on my host file
For some reason your system denied write access to the Hosts file. If any hijacked domains are in this file, HijackThis may NOT be able to fix this.
If that happens, you need to edit the file yourself. To do this, click Start, Run and type:
Notepad C:WindowsSystem32driversetchosts and presenter. Find the line(s) HijackThis reports and delete them.
Save the file as ‘hosts.’ (with quotes), and reboot. For Vista:simply, exit HijackThis, right click on the HijackThis icon, choose ‘Run as administrator’.
Now I am not sure how to detect if my machine has an infection or not.
Anyone has any ideas?
Your system denied write access to the Hosts file HijackThis
Please pay attention to several recommendations because of this resolve:
Avoid making any adjustments in your PC such as installing/uninstall programs, removing files, adjusting the particular computer registry, as well as operating readers or equipment. This might lead to adjustments for the instructions I have to offer you and also prolong enough time necessary. Additionally, you shouldn't end up being getting any assistance relating to this PC from any other resource all through the path of this particular resolve.
If you don't realize any kind of step(s) supplied, make sure you don’t hesitate to inquire about before ongoing. I might prefer to clarify guidelines or even clarify these in different ways compared to have something important broken.
Even though issues seem to be far better, it will not imply we are finished. Make sure you always stick to my own directions as well as respond back again till I supply you with the "all clean". We all should not clear a person part-way, simply to achieve the method re-infect by itself.
Make sure you response with the entire switch in the reduce correct palm corner of one's screen. Usually do not start a new matter. The logs which you submit should be pasted into the respond. Only connect all of them if asked for or perhaps in the event that they just don't fit into the particular post.
Old matters tend to be shut right after 3 days without response, and dealing matters are closed right after five days. If unconditionally you cannot total guidelines within that time, that’s great, simply post back here therefore that we know you might be still right here.
You should arrange your system to show all files.
Simply click Start, My Computer, Tools menu and click Folder Options.
Select the View Tab. Under the Hidden files and folders heading, select Show hidden files and folders.
Uncheck: Hide file extensions for known file types
Uncheck the Hide protected operating system files (recommended) option.
Click Yes to confirm.
