I have an LG G2 phone and I cannot use YouTube in it. I mean I can use but the videos wont show in You Tube only sound is played and that's all. I thought that the slow internet may be the cause but the problem is same in an average and fast network too. The problem occurred after the last update of You Tube on my android phone. Is the update corrupt or my phone didn't handle the new update? Please I want to see a lot of videos on You Tube.
Your LG G2 Smartphone is running on Android 4.2.2 Jelly Bean and if you encountered a problem on the YouTube app after updating the application, the problem is probably with the app itself because a lot of people are complaining with several problems after updating. Try deleting the app from your phone and then download the latest YouTube App again from the Google Play Store.
See if it works. If this doesn’t work and you still have problems with the app, try downloading the old version from YouTube Previous Versions then see which one works. Anyway, here are the specifications of your phone. Your LG G2 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, CDMA, HSPA, EVDO, and LTE technologies.
LG G2
It was announced to the public on August 2013 and released on September 2013 measuring 138.5 x 70.9 x 8.9 millimeters and weighing 143 grams. Its body is made with plastic and uses micro-SIM card. It has True HD-IPS + LCD capacitive touchscreen display with 16M colors at 1080 x 1920 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass 2.
It runs on Android 4.2.2 Jelly Bean upgradable to Android 5.0.2 Lollipop powered by Qualcomm MSM8974 Snapdragon 800 chipset, 2.26 GHz Quad-Core Krait 400 processor, and Adreno 330 GPU. It doesn’t support microSD. It runs on 2 GB RAM with internal storage available in 16 GB and 32 GB capacities.
The primary camera supports 13 megapixels with f/2.4, 29mm, 1/3″, 1.12 µm, LED flash, autofocus, and OIS featuring geo-tagging, face detection, and HDR. It supports 1080p video recording at 60 fps with HDR and stereo sound rec. The secondary camera supports 2.1 megapixels and supports 1080p video recording at 30 fps.
It has 3.5-millimeter jack featuring 24-bit/192kHz audio, Dolby audio enhancement, and Active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP, LE, and aptX support; GPS with A-GPS and GLONASS support; NFC; infrared; stereo FM radio with RDS support; and microUSB 2.0 SlimPort with USB Host support. It has built-in accelerometer, gyro, proximity, and compass sensors.
The pre-installed web browser supports HTML5. Java is not supported. It runs on non-removable Li-Po 3000 mAh battery with standby time up to 790 hours on 2G and 900 hours on 3G. Talk time is up to 16 hours 30 minutes on 2G and 17 hours 30 minutes on 3G. It is available in black, white, gold, and red colors.
1....
