Goldie Bond
20 points
Posted on - 08/20/2012
I am using a zandronum server at my office.
Recently zandronum is sometime giving me this error. please can you tell me the possible reasons of this error.
zandronum cannot be opened because of a problem.
Check with the developer to make sure zandronum works with the version of MAC OS X. You may need to reinstall the application. Be sure to install any available updates for the application and Mac OS X.
Zandronum cannot be opened error
For your situation, you need to install the Combo updater so that you will not encounter or avoid some unusual error. You can find the downloads here https://support.apple.com/kb/DL1048?locale=en_US
Register also the iWork '09, or just use the demo version. If you have iWork '09, try to re-install that, you might not have migrated or installed the installation correctly. If all the recommendations above did not work, you may need to re-install all again from the scratch. Just make sure to do the correct installation of installer that you are going to install so you will not encounter any problem. Hope this will helped.
