Zend studio 5.5.1 on Windows XP
I have downloaded Zend studio 5.5.1 from zend website, then installed. When tried to open i got loading box, seems to have loaded, even got tip of the day box. but there is nothing showing behind them. please anyone help me to solve this problem.
Best Answer by Slaterable Postor
Answered By 0 points N/A #147636
try reinstalling it, if it doesn't solve the problem try downloading a new installer from the site it might be the cause. try turning off other applications of your anti virus might be a cause of conflicts..
Answered By 0 points N/A #147637
Many people are facing the same issues but later on found that most of them have ignored  something  or the other  in the installation process. So I think you have also overstepped something in the installation processin. In fact Zend Studio 5.5.1 works well in Windows XP than in Windows 7.
Here I am showing you exact installation process, you follow them and you are done.
1: Download and install JRE and WinRAR.
2: Download Zend Studio 5.5.1.
3: Extract the file in WinRAR.
4: Open the folder and you will find a folder called windows and then open windows folder and you will find a folder called resource.
5: Open that resource folder and you will find “jre” . Just rename it to “jre backup” .
6: Go to C:/ Program files and copy the folder in which  Zend Studio 5.5.1 is installed and paste it in the resource folder and rename it to “jre” .
7: Go to the Windows folder and there you will find Zend Studio 5.5.1.exe file. Install it.
8: Now copy the “jre backup” and paste it in Zend Studio 5.5.1 installed folder and then again rename ‘jre’ to ‘jre another backup’ and ‘jre backup’ to ‘jre’ .
Thats it . Hope this solution helps you.
