alec hughes
20 points
Posted on - 05/10/2012
Hello experts!
For the past year I’ve been running a registered Zmodeler.
But now I received the following error message when I try to start Zmodeler 2.2.
Please help.
Thanks in advance.
Error:
"C:Document and SettingsAll UsersStart MenuProgramsRecentxRecentX.lnk"
This application has failed to start because the application configuration is incorrect.
Reinstalling the application may fix this problem.
Zmodeler 2.2 failed to start because of faulty configuration
When Zmodeler 2.2. introduce and release in the market, there was also an update on Microsoft library. Hence, Zmodeler 2.2 launch has some flaws, especially the updated version. It is advisable that you will download from Microsoft by following this link: https://www.microsoft.com/en-us/download; This is for windows/vista with 32 bit. if you have 64 bits , use …st_x64.exe. and Zmodeler 2.2. requires an installation of C++ Redistributable package with ATL security package. Download and install "vcredist_x86.exe". both for 32 and 64 bit.Or download https://www.microsoft.com/en-us/download/details.aspx?id=14431; Just be sure that your registration is not an illegal key. and you have a windows installer of at least 3.1 or higher.
