wirt yule
50 points
Posted on - 09/05/2012
Hi folks, anyone can help me on how to fix this error. I’m getting stuck when I tried my cod mw3 backup files download in the internet. After doing this procedure it got an error in zone folder. Its says that some files in zone folder are missing. Thanks!
Zone folder got error after my cod mw3 backup files download in the internet
If this is the first time you’ll be using the application, try restarting your machine then try it again. Maybe the error was just a glitch. If still nothing happened, try doing a clean installation of the program to fix any missing files that were previously reported by the program. Uninstall the application then restart your machine when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics test on your computer, use disk utility applications like PC Tools Performance Toolkit, Norton Utilities, or Norton SystemWorks. Install it again then see if you are now able to use it.
If the program you are using was downloaded from a website, try downloading a different installer from a different website. Or much better if you can find a much newer version than the one you are using.
