ZoneAlarm Internet Security Suite 9
Hi Techyv,
Will Windows Vista supports ZoneAlarm Internet Security Suite 9, What are its special features compared to other similar Internet Security Suites. Please guide me, as I am planning to have Windows Vista supports ZoneAlarm Internet Security Suite.
Thanks,
Adam Johnson
Best Answer by
Answered By points N/A #136978
Internet Security Suite by Zone Alarm is compatible with Windows Vista.
If you wish to have Windows Vista and run Zone Alarm Internet Security Suite, your system should meet these minimum requirements.
1.       32-bit or 64-bit OS
2.       2 GB RAM
3.       2 GHz processor speed
4.       HDD Space: 250 MB
It is an advanced firewall that monitors every execution of data for malware protection. It is also able to prevent data bypass by viruses.
Its privacy is also awesome. No one is able to track you online. Your identity is kept safe from anyone. Private browsing is also a plus point.
Its user-friendly UI is also a good point.
That’s why it is different than the others and made it popular.
Answered By 15 points N/A #198862
Hi Adam,
Windows Vista supports Zone Alarm Internet Security Suite 9.
Comparing with other security suites, the special features are:
1) Zone Alarm is firewall software application that includes intrusion detection system
2) The network connections are divided into zones, through which the program access is controlled
3) It provides excellent protection against viruses, spyware, worms
4) True Vector Security Engine is a windows service that monitors traffic and creates alerts for unidentified users
5) Smart Defense Advisor is a service which utilizes a large database of trusted program signatures
6) Zone Alarm is a free individual security software
7) Zone Alarm is effective for removing errors in computer software and peripheral devices
