While running a mp3 file, I got an error message which says,
The Repair effect is intended to be used on very short section of damaged audio (up to 128 samples).
Zoom in and select a tiny fraction of a second to repair
Do you know how I can fix it up?
Please help.
The problem could be that you have downloaded a corrupted mp3 file. So first and foremost install the same file from some other source or some other website. The issue could also be the Player that you are using to play the file. So if the new file also does not work then download a different media player to play the file . Here is the link for one such player https://vlc-media-player.en.softonic.com/
