Zoom player cannot play .avi format file
Howdy,
Got an error message in zoom player while I am trying to play a song. The error message states me that audio format is not supported. I played the .avi format in windows player it is playing there. Sometimes I am getting error when I try to close the player. Is anyone have experienced this problem, please share your ideas. Thanks for your help.
Title: Problems with .Ts files
An ERROR has occured!
Pin Connection Error:
[Zoom Player Audio Filter]. Output —> [Envy24 Family Audio (WDM)].Audio Input pin (rendered)
Code: Cannot play back the audio stream: the audio format is not supported.(8004025C)
