Please read the question carefully and help me solve this problem. I have zoomed in while browsing for convenience and I used to do it in my Mozilla Firefox browser using (Ctrl++). Recently it is not working and I am having some real trouble. I have already tried to zoom in with manual mouse option. But it did not work either. Please help me solve this problem as quickly as possible.
karlos Hilton
Zooming is not working in Mozilla firefox
Hi there,
I guess you are having trouble with the zooming function in your Mozilla Firefox,
I recommend you uninstall the Mozilla and then download a fresh one from filehippo.com and then install it, and try if that problem persists,
If YES, Try my following methods carefully: –
1. Click on start.
2. Go to accessories by clicking on it after clicking All programs in the start menu.
3. Click on ease of access folder which is there in accessories folder.
4. Click on magnifier which you can see in it and there comes a stuff like the below screenshot.
Now adjust the zooming in and out by pressing the + or – button respectively, there are a lot more settings you can adjust for your convenience.
There are also several shortcuts for zooming in and out respectively.
