Zotac ZBox Nano XS AD11 Plus mini PC
 ZBOX Nano XS AD11 Plus has a dimension of 106mm x 106mm x 37mm which makes it ideal for room with limited space.
However, does it have any room for future expansion and upgrade?
Hi Jopreciados79!
Though you can see the internal hardware of the new mini PC by unscrewing its legs, you cannot do any user related upgrade to it.Â
* Unlike other Zotac ZBOX Mini PCs, the Nano XS AD11 Plus is only available in a completely assembled PC because there are no available bare bone option materials for the AD11. Therefore, no external upgrades can be made.
*The internal materials of NANO XS AD11 is custom-sized and is not appropriate for user upgrades. As a proof, ZOTAC opted to use 64GB mSATA SDD than an AMD E-450 Based System because it can not even accommodate a 2.5" hard drive.
Hope this answer your question!
