Zune software installation error occurred
Today, I got an error message when I was trying to install Zune software and the installation failed. I downloaded this amazing software without having any issue but when I attempted to install this software the installation failed. This is very annoying to me. I have tried to reinstall the software but the error still exists. I want to fix this error so help me.
Thanks for any assistance.
Installation Failed Setup must stop because the required package Zune didn’t install. Error code: 0x80070643 https://support.microsoft.com/en-us/help/11696/windows-phone-7
Answered By 15 points N/A #168338
Hi Sandra,
The Zune installation error is because some of the system component. required for installation, are missing.
Check for the below list of minimum system requirements for installation:
a) Windows 7 / Windows 8 / Windows XP with SP3 / Windows Vista
b) 256 MB RAM
c) 64 MB Video card
d) Microsoft Internet Explorer 6 or higher
Answered By 590495 points N/A #327338
You may receive error code “0x80070643” when you try to install Microsoft Security Essentials, Windows Live Essentials, or a specific Windows Live application such as Windows Live Messenger. The problem happens because the previous installation or the old installation puts the computer in a state where there is a pending restart. To fix the problem, try restarting the computer then reinstall Microsoft Security Essentials.
When reinstalling, don’t uninstall the existing version. Just run the installer of Microsoft Security Essentials to install over the existing installation. On the other hand, if you keep getting this error when installing a different program like the Zune software, restart the computer and try again. If this doesn’t work, uninstall Microsoft Security Essentials, Windows Live Essentials, or any Windows Live application if you have any.
Download the free version of Revo Uninstaller and install. Once installed, start Revo then select Microsoft Security Essentials, Windows Live Essentials, or any Windows Live application among the programs then click “Uninstall”. Follow the normal uninstall process. When you are prompted to restart the computer, click to restart later. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, exit Revo then restart the computer. If you want to install Zune software but you keep getting an error, check the system requirements again and verify that your computer meets those requirements. Download Zune Software 4.8.2345.0 on FileHippo. It supports Windows XP Service Pack 3, Windows Vista Service Pack 2, Windows 7, and Windows 8.x.
Zune is a discontinued media management application designed for Microsoft Windows. It works as a full media player application that includes a library, an interface for the Zune Marketplace, and can also function as a media streaming server. Zune software was discontinued on October 16, 2012 and replaced with the Windows Phone App.
